Bleeding brakes / master cylinder on hydroboost
pauldolgner@hotmail.com's avatar
pdolgner's avatar
pdolgner
So I am not an expert on brakes... With that said; I am having trouble with my own set up.  I have a hydro boost on my truck.  I bleed all four wheels but the pedal is still on the floor without and firmness.  Do I need to do something to the master cylinder?
choppedn22d's avatar
choppedn22d
Did you bleed the master cylinder? It needs to be bled first on the bench unless your talened and are able to do it on the truck. Then youll bleed each wheel starting with the wheel farthest away from the master.
pdolgner's avatar
pdolgner
The master is in the truck so bench bleeding is out of the question.. Can I do it in the truck?
1lowdiesel's avatar
1lowdiesel
Edited: 2/9/2010 8:29:10 AM by 1lowdiesel
sometimes with hydro boost trucks you will need to get a TechII scan tool and pulse the ABS to get the air out. i was having a problem bleeding mine a while back and read that in the GM book.
