i have 2 3 gallons on my yota but not sure if i need 2 ..im done playing with the switchs ...so would one 3 gallon with my 2 480s work ...its what i had th 1st time around and then i added another 3 gallon ...the main reason is so the comps do run so long ...
tuckinlugs06
Edited: 2/9/2010 9:25:38 PM by TuckingLugs05
Edited: 2/9/2010 9:24:08 PM by TuckingLugs05should i leave the tanks or would it be ok with the one tank...also its the 3 gallons with the 1 port on each end ...
Layumon22s
Edited: 2/9/2010 9:43:38 PM by Layumon22s
It depends a lot on your pressure switch and what pressure you drive your truck at. 3 gallons at 200 psi should be enough. I have 2 480s on 2 3 gallon tanks with a 145/115 switch and it does just fine. Maybe consider doing that, your comps will last longer and run a lot less plus its really easy to do
tuckinlugs06
well right now its 165/200 with the 2 3 gallons and when i had the 1 3 gallon i had the same p switch ...and when i had the 1 it filled so fast ...also i just swap for a v8 so will the one 3 gallon work fine with the added weight ...
