Toyota Trucks \  info on the grant yota bumper
Toyota Trucks Make Specific
views 665
replies 11
following 5
tuckinlugs06   +1y
some one is selling one of the toyota bumpers for a nissan ...are they just the same just the brackets are made to fit it...or is the bumper made to fit the fenders ...please post pics of these installed
lumpy   +1y
Edited: 3/2/2010 2:46:35 AM by lumpy
idea why dont you ask the guy how it mounts up .......sounds easy huh...................... but maybe not im guessing
tuckinlugs06   +1y
no im buyin it off someone to put on my yota ...
jetts   +1y
im guessing its made to fit the lines of a nissan
tuckinlugs06   +1y
ok it lines up with the new front just need to know if stock 4runner brackets will work tomount this ...i found out they start with a 94 style 4runner bumper so im guessing stock brackets would work
dragnlow   +1y
Edited: 3/3/2010 1:05:49 PM by dragnlow
You have to modify the front frame horns to get it to line up correctly cause it sinks in tighter than the regular bumper The stock brackets worked for mine though but mine were not sure if they were 4 runners though
tuckinlugs06   +1y
ya but when i have the stock 94 runner bumper i had to get 4runner brackets and it bolted up...since this bumper started as the same bumper should the same brackets work...to bad i sold that bumper with the brackets i used..i have a set of stock 2wd toy pickup brackets and they bolt to the bumper but are to skinny to fit the frame horns...i guess ill just cut and make my own out of the nissan brackets that came with the grant bumper
maz duh   +1y
Call Grant Kustoms and ask them, I'm sure they will be able to tell you in about 2 seconds what the deal is.
tuckinlugs06   +1y
i have i called and emailed ...no responce
---------------------------------------------Originally posted by dragnlowEdited: 3/3/2010 1:05:49 PM by dragnlowYou have to modify the front frame horns to get it to line up correctly cause it sinks in tighter than the regular bumper The stock brackets worked for mine though but mine were not sure if they were 4 runners though---------------------------------------------you have any better pics of your bumper ...the one in your profile you cant see it well
dragnlow   +1y
I'll take a look on my hard drive.
