Chevy/GMC Trucks \  c -10 rolling chassis
views 221
replies 1
following 2
tacomaon24s   +1y
we are building c-10 chassis now full rolling. upper and lower control arms that will lay a 24 inch wheel with a descent size tire, body mounts setup up to lay body, has rear paralell link , all delrin bushings and fk heim joints. All you have to do is transfer the cab and front clip over. we offer 2 diffrent rear frame setups one you are required to body drop the bed floor to clear the rails and the other is cut out for the axle and "bridge" to come through. The rails will be mandrel bent front to back, all the tabs are tig welded and laser cut out.  All chassis can be custom built to your specs. Price on that will vary depending on complexity. The  normal front to back mandrel bent rolling chassis will start at  $4000.00. remember that is upper and lower arms with the link and cab and bed mounts.
no1lowr   +1y
pics would be a great helper for your thread!
