Air Ride Suspensions \  civic and integra struts
Air Ride Suspensions Q & A
views 336
replies 6
following 5
decivic   +1y
will struts from a 92-95 civic fit on a 99 integra 4dr ls?
FADE2BLK94   +1y
Yes, 92-00 civic and 94-01 integra use the same struts and spings.
4DOORWHORE   +1y
x2
cuzican   +1y
---------------------------------------------Originally posted by FADE2BLK94Yes, 92-00 civic and 94-01 integra use the same struts and spings.---------------------------------------------Not exactly, but they are close enough to work. Length and mount wise they are the same (excluding the Integra type-r rear struts). The difference is that the 92-95 civic struts have the bracket for the brake line and the 96-00 civic struts do not since the brake line is bolted to the spindle. Also I'm not 100% on this, but i also believe that there is a slight difference in the springs from the 92-95 to the 96-00 civics because the 96-00 weighed a little bit more. I'm not sure with the brake line configuration on the  integras, but it's nothing a couple of zip ties can't fix.
decivic   +1y
thanks guys
FADE2BLK94   +1y
---------------------------------------------Originally posted by cuzican---------------------------------------------Originally posted by FADE2BLK94Yes, 92-00 civic and 94-01 integra use the same struts and spings.---------------------------------------------Not exactly, but they are close enough to work. Length and mount wise they are the same (excluding the Integra type-r rear struts). The difference is that the 92-95 civic struts have the bracket for the brake line and the 96-00 civic struts do not since the brake line is bolted to the spindle. Also I'm not 100% on this, but i also believe that there is a slight difference in the springs from the 92-95 to the 96-00 civics because the 96-00 weighed a little bit more. I'm not sure with the brake line configuration on the  integras, but it's nothing a couple of zip ties can't fix.--------------------------------------------- maybe slightly different but aftermarket springs and struts have the same part #'s
decivic   +1y
---------------------------------------------Originally posted by FADE2BLK94---------------------------------------------Originally posted by cuzican---------------------------------------------Originally posted by FADE2BLK94Yes, 92-00 civic and 94-01 integra use the same struts and spings.---------------------------------------------Not exactly, but they are close enough to work. Length and mount wise they are the same (excluding the Integra type-r rear struts). The difference is that the 92-95 civic struts have the bracket for the brake line and the 96-00 civic struts do not since the brake line is bolted to the spindle. Also I'm not 100% on this, but i also believe that there is a slight difference in the springs from the 92-95 to the 96-00 civics because the 96-00 weighed a little bit more. I'm not sure with the brake line configuration on the  integras, but it's nothing a couple of zip ties can't fix.---------------------------------------------maybe slightly different but aftermarket springs and struts have the same part #'s---------------------------------------------im takin air cylinders from a 92 civic to put on an 99 integra so thats news i wanted to hear
