Chevy/GMC Trucks \  Bagging 2002 Envoy Need Help Pics
views 557
replies 4
bagged454   +1y
im getting ready to to bagging my envoy was wondering best way strut bags are cylinders are even making a custom front setup thanks in advance any pics would be great
ahab   +1y
The best way to bag the front of that truck is to do it just like a torsion bar mini truck.  just run a bag on the lower arm with the top mounts welded to the side of the frame.  With an air cylinder or a strut bag you wont get enough lift and it will ride like shit with cylinders.  If you look up "AONteach on here, I did the setup on that truck.  Should have some pics in the profile.  The rear of that truck is a bitch though if you really want it to lay frame.
bagged454   +1y
thanks man i saw the pic was just wondering it look like the drive shaft would be in the way mine is all wheel drive
tealchevy   +1y
I had my wifes 02 trailblazer done. lays frame on 22's. The front is very simple but the back you have to cut into the doors and rework the latch and jambs. here is a link with plenty of pics...
http://www.streetsource.com/forum/topic.aspx?topic_id=108272&page=1
ahab   +1y
Ya you cant run the bag like that if its all wheel drive.  You could possibly build a hoop that the axel can go through and put the bag on that.  On the green envoy we didnt have to change the rear door latches.  If you run a small 22 inch tire you will just have to remove the child safty shit and cut a good chunk out of the bottom of the door.
