new to bagging a truck
ryan92
im new to all this and was wondering if someone could upload some pictures of their front setup for their bags, and do you have to have ew control arms or can you use stock ones?
truck action's avatar
truck action
What year truck??
low24gmc
i want to bag my 00' gmc sierra myself  and wanted some info on how to install the four link and the airbags. I want to get a good lift out of it. i'm running 24s with 275/30/24 tires any info and or pics would be a great help. also how to figure axle/four link placement.  I'm new to this but I am good with mechanics
splitdecision's avatar
splitdecision
As far as the Sierra goes you will either need new control arms or drop spindles/knuckles to lay out the front on 24's. On the rear I have my lower bars outside the frame with a bag on bar setup and my upper bars are reversed. It's not the greatest setup but it does the job. I would recommend doing a wishbone 3 link upper bar forward instead of reverse upper bars if you are starting from scratch and you can still keep the gas tank in the stock location. You will need to cut and raise the gas tank crossmembers though otherwise the tank will drag.
