Chevy/GMC Trucks \  1995 crew cab chevy...need help in front
views 248
replies 3
layedouton22z   +1y
95 crew cab dually...bagged in front and rear...just bought some milled down alcoa  22s...i think 265-35-r22 tires(rubberband)...    350 engine...basically what will i need to do to get them in the front fenders  ...i was told to get one ton rotors and that would do it.....i am sure it has been done...help a brother out......any suggestions would be appreciated...thanks
severedbrandon   +1y
Just get 3/4, or 1 ton non dually hub/rotor assy.
okcderek   +1y
Is the truck not already a 1ton? If not, you will need either 1ton suspension or 3/4ton hubs/rotors and have extended arms built cause wheel will set in too far w/ just 3/4ton arms and spindles.
layedouton22z   +1y
i believe its a 3/4 ton      is it possible to do with stock arms?  should just the swap be enough?thanks
