what steering knuckle to use?
groundedwatts
hey, i've got a 94 yota pickup with a SFBD. The steering is currently not working. I'm trying to figure out what kind of steering knuckle alternative I have aside from stock. Is it possible I could make a fullsize Tahoe ('95) knuckles work as I already have some around.
What other options could I look into?? Thanks!
mindlissmetalfab's avatar
mindlissmetalfab
What about the steering is not working?
groundedwatts
well, i got this truck in like a 50% finished condition. I haven't actually put it on the lift and taken the wheels off to know exactly what is wrong. I just know that I was told I needed to get new knuckles for the front. I can spin the steering wheel with no effect. I can move each wheel independently of each other. need pictures??
theinternetkid's avatar
theinternetkid
I'm using Flaming River for my 72 C10 build, I got them from CPP.  Check out http://www.classicperform.com/.
cajuntaco's avatar
cajuntaco
---------------------------------------------Originally posted by GroundedWaTTswell, i got this truck in like a 50% finished condition. I haven't actually put it on the lift and taken the wheels off to know exactly what is wrong. I just know that I was told I needed to get new knuckles for the front. I can spin the steering wheel with no effect. I can move each wheel independently of each other. need pictures??---------------------------------------------This is pretty broad.  Are any of the following non-existant or missing: Steering Box, Pitman Arm, Idler Arm, Center Link, Inner Tie Rod, Outer Tie Rod, knuckles?? Obviously your steering column is not connected through all these parts to the knuckles.  If the knuckle/spindle is mounted with wheel and whatnot and does not have a broken steering arm figure out what is missing.  Installing knucles off of another vehicle with no insight or design to adapt them will result in horrible suspension geometry, bump steer, tire wear.  In a nutshell, we need more information, pictures would be even better. -Ryan
groundedwatts
---------------------------------------------Originally posted by BagD72Chevy---------------------------------------------Originally posted by GroundedWaTTswell, i got this truck in like a 50% finished condition. I haven't actually put it on the lift and taken the wheels off to know exactly what is wrong. I just know that I was told I needed to get new knuckles for the front. I can spin the steering wheel with no effect. I can move each wheel independently of each other. need pictures??---------------------------------------------This is pretty broad.  Are any of the following non-existant or missing: Steering Box, Pitman Arm, Idler Arm, Center Link, Inner Tie Rod, Outer Tie Rod, knuckles?? Obviously your steering column is not connected through all these parts to the knuckles.  If the knuckle/spindle is mounted with wheel and whatnot and does not have a broken steering arm figure out what is missing.  Installing knucles off of another vehicle with no insight or design to adapt them will result in horrible suspension geometry, bump steer, tire wear.  In a nutshell, we need more information, pictures would be even better. -Ryan --------------------------------------------- This is pretty much what i was looking for....and like i said, i havent had the chance to get her on the lift so Im not 100% sure what is there and what is not, was just told it needed custom knuckles or ones from a fullsize chevy. So'll this weekend or sometime this week i'll get some pictures and maybe some more insight.thanks
BAD_INC's avatar
BAD_INC
MOOSE
groundedwatts
LMAO...nice
groundedwatts
So, i got some pictures and i will get them uploaded this afternoon....the knuckles LOOK alright. New tierods are in order but the main issue I'm seeing is the Steering shaft is completely hacked off. Doesn't look like I'm going to be able to use stock steering assembly here. I've checked out flaming rivers stuff in relation to this but what other options might i have?and ill def. get some pictures up tonight though
