GM Fullsize extended cab two piece drive shaft angles
BLACKFULLSIZE
I really need help with the angles for the two piece drive shaft and, need them from someone with 5-7" drop or air suspension. Please help. I am needing them for a baseline of where to position the carrier bearing. My transmission is -3.5 and I need the rest of the angle from there. I can't raise my transmission tail anymore than what it is already. Thanks to any that can help!!
low24gmc
i have an 8 inch drop ithe rear using a flip kit i used a carrier bearing relocater and when i installed it i pushed the drive shaft bracket all the way and i have no vibration hopefully this helps
