Body work and Paint \  paint gun prob...
paint gun prob...
Body work and Paint Q & A
views 326
replies 3
clownen   +1y
i have a devilvis finishline and it started poring paint out by the handle anyone know how to fix.........i dont  paint all the time ..it might be an easy fix ..thanks
AZ ARTWORX   +1y
Try tightening the needle packing nut, which is part number 25 on the breakdown schematic for that particular gun..Don't tighten it too tight because that may cause your needle to bind when spraying...If that doesn't work, you'll need to by part 24(needle packing o-ring). When you soak them in lacquer thinner, they swell really bad & then shrink back down when they dry. This could be the cause of your leak..
BK2LIFE   +1y
..ditto on what he said
crazygenius13   +1y
--------------------------------------------- Originally posted by AZ ARTWORX Try tightening the needle packing nut, which is part number 25 on the breakdown schematic for that particular gun..Don't tighten it too tight because that may cause your needle to bind when spraying...If that doesn't work, you'll need to by part 24(needle packing o-ring). When you soak them in lacquer thinner, they swell really bad & then shrink back down when they dry. This could be the cause of your leak.. --------------------------------------------- I like your approach on deadline gaurantees. Great idea
