will it fit?
jt_haley@yahoo.com's avatar
will it fit?
crzyone1013's avatar
crzyone1013
what is the biggest engine you guys have seen in a toy? I have only seen small blocks in them so far but I really want to see if a big block will fit in one. and if you guys have any pics of the engines you have seen in them then post them up please.
kaoss's avatar
kaoss
Not a yota, but along the same lines. www.bigblockranger.com
mjavy7's avatar
mjavy7
I've seen a bbig block on a yota with the radiator in front of the support and a elctric fan to make it fit.
waynehammer's avatar
waynehammer
Edited: 3/31/2010 10:12:06 AM by waynehammer
it seems like every month you post a new thread about changing your engine. are you ever gonna change it? i dont think your suspension up front will handle a big block if you plan on going fast or drag racing it. you would probably wanna put some bigger brakes on too
tuckinlugs06's avatar
tuckinlugs06
after i put the sbc in mine im pretty sure a big block would fit with about the same work i did
tuckinlugs06
id post pics but i have to resize everypic and thats old
cajuntaco's avatar
cajuntaco
I don't see how a big block will fit.  My small block's block hugger headers are 1/4" from touching both upper arms.  My engine sits really low, so maybe if it sat a little high.  An LS1 is about as wide as a big block for good measure.  I haven't seen one of them in a yota either.  Anything is possible but I squeezed the small block in wth stock firewall, relativelly stock rad support, 2.5" thick radiator and all the A/C bits.  Def can't do that with a big block.
tuckinlugs06
nothing is impossable ...if you want a big block in there you can make it work custom headers, remote oil filter, widen frame rails ....also if i had a big block i  wouldnt care if i had a stock hood or not
sparage's avatar
sparage
Eddys truck has a big block in it right now or at least it did at blood drag.
