Toyota Trucks \  2600lb bags in the front on a 89-94 yota
Toyota Trucks Make Specific
views 339
replies 3
pmiller   +1y
Anyone out there squeezed a 2600lb bag in the front of a 89-94 yota?
I bought some for my s10 project but I've run into a snag with the engine.
cajuntaco   +1y
I got RE7's in the front of my yota.  I recomend at least tubular lowers with screw in BJ's to help with clearance for the bags.  I dont see it happening with stock arms.  tubular uppers with screw in Bjs, or uniballs will help get the usable lift.  I'm getting 11" and my upper arm hits the bag.  I'm making new arms with uniballs to get another 1" or 1.5".  I should have a solid 12" with a small block up front! -Ryan
tuckinlugs06   +1y
i got re7's with stock lowers ...as long as you set it up right you can clear the strut brace and the 3rd bolt for the ball joint but i have seen people cut the back bolt off but then again you only have the 2 bolts holding it
NR RailnPup   +1y
ya im running a 1986 yota clip on my isuzu and im running 2600s up front no problem w/ stock uppers (only pie cut for 20s) and stock lower control arms, i get 10.5" of lift.
