how to remove 95 up isuzu rodeo dash?
F
framekiller
i want to swap dashes out of an 95 up isuzu rodeo. where are all the bolts and how hard is it to take out? what will i need to swpa over to an 92 isuzu p/u. i figured ill need the dash and steering column is there anything else?
onelozu
pull the main bezel and all the way on the drivers side theres one bolt,if im not mistaken theres two in the middle right there,then theres one behind the little vent all the way an the pass. side,theres a couple around the main bracket by the floor,you need the black piece that runs across the windsheild with the vin on it or cut holes in the stock one for the dash to slide in,you need the brackets that bolt to the sides of the cab and the big pipe that goes across,the middle bracket is also needed,you have to make brackets to be able to the floor,i ran my stock steering column and ran my lights and wipers to toggle switches,i modded my stock cluster also,i went to the junkyard and had it out in about an hour so its not too hard
Related Discussions in Isuzu
