130 amp alternator swap
kyllokustoms@yahoo.com's avatar
jealousonezenvy's avatar
jealousonezenvy
ok so im trying to do my alternator swap. On the stock mazda alternator i got the black wire to the battery thats positive. I got the plug that has one white wire with black and one black wire with white, then the single yellow wire which i think goes to the carb heat spacer.. When i swap to my ford 130 amp alternator it has A S I... does anyone know what wires go where?
mazdog93
http://mazdabscene.com/forums/viewtopic.php?f=32&t=17824 http://mazdabscene.com/forums/viewtopic.php?f=32&t=11813&st=0&sk=t&sd=a&hilit=gm+alternator  Hope these help!
jealousonezenvy
ok genius if you would have read my post it says the bscene write up didnt help.... thanks for trying hope you aint drivin
bagdb2200
---------------------------------------------Originally posted by jealousonesenvyok genius if you would have read my post it says the bscene write up didnt help.... thanks for trying hope you aint drivin--------------------------------------------- How did it not help?  I just read the top one, and the guy has a WIRING DIAGRAM showing which wires go to the A S I and Battery + for the Ford alt.
jimmy726's avatar
jimmy726
you know maybe im am missing it but i dont see where you put that. And dont be such a dick if the guy made a mistake atleast he took time out of his day to try and help your sorry ass.
jealousonezenvy
I dont know if you are readin my post or not... Listen the guy who wired his alt had a red and white wire mine doesnt have a red and white wire...m ine has a balck and white stripe and white and black strip to the alternator and the yellow which is the idle crap.. Does any smart person know which one plugs into the A S I locaion on a ford alternator?
Kyrasis6's avatar
Kyrasis6
I'm not sure if this will help or not..  http://www.mazdatruckin.com/vBulletin/performance/3820-130amp-ford-alternator-swap.html Pay special attention to the white and black wire which jumps over to the field as shown about 2/3rds down the page. I would also like to point out that several people who have mounted the alternator upside down to make the install easy have had the brackets break off shortly after. Welding up some new alternator brackets is recommended. -Kyrasis6 Mazdatruckin.com
