dc7500 air compressor
9
96canedcivic
Has anyone used it, and if so what did you think of it?
bd91gmc
bump has no one used them before
shpaint1's avatar
shpaint1
kinda wounder this my self????
firefighter5325's avatar
firefighter5325
I am running one on my 2008 tundra crewmax I havnt ran it long enough to give a proper review the truck should be finished this coming week and will get to put some drive time on it.  the compressor has a preety good fill time but my truck has huge air requirements so I am running it alot more than I would like.  My set up is 1 dc7500 filling 2 5 gal stainless tanks.1/2" air engine manifold.  1/2" air line 4 slam-r' 8 bags.  this is all under a 7300lb truck so it has a healthy air appetite.  If I was a switch happy person this would not be enough. however I honestly fill that the only electric air compressor on the market that would be enough for my setup would be a oassis.  I am ethier adding another dc7500 or a EDC to my set-up.
BuddiesGarage
I have run several "DC series" compressors over the years. They are junk; mainly because they have a short life span & Shaim will not sell parts for the motor. Also, once I needed a piston & cylinder. I was forced to buy a head & crank case I didn't need. SO: stay away from them.
seansbass
I have one on my 07 Tahoe and I think it works fine. The downer is that it is pretty loud compared to dual viairs but the fill time is really fast. I have a 9 gallon and it takes about a little over a minute or so to fill from 115 to 145. This is my daily driver and this winter I had some pretty steady leaks throughout and i ran it hard, after 7 months of steady running it, i had the inlet flap shatter and get into the piston seal, for about $30 plus shipping I rebuilt it in under 30 minutes... I think its worth the money to be able to run it hard and be able to rebuild for cheap instead of replacing.
N
Numbskull
Ive used them..had one that lasted about 5 show seasons until it slowly degraded in performance. Also have had alot of friends that have used them, the most common problem i have seen is the entire head snaps off at the body of the compressor. Very loud and vibrates pretty hard. I wouldnt use one on a daily but for a show vehicle they are ok.
firefighter5325
like above iv got one on my 08 crewmax tundra i have now ran it for a few months.  the comressor is doing good it just does not like the high pressure i would say its great for anything below i would say 175.  my setup is 165-200 so it has some trouble with that.  I will soon be adding 2 obd2's to suppliment it.
blazins10's avatar
blazins10
i have had 2 dc5000 for 5 years now and never had an issue with them , they fill alot faster than my viairs but really loud but its a very short run time
