factory rear end???
factory rear end???
1987bseiresman
what does a 1987 mazda b2200 se-5 4-cyl, 5-spd standard have from the factory??? i use to own one monoleafed on 3inch blocks and no torison bars.i was going some where and to stop along side the freeway to put something in my truck because it eas raining. i live in washington state. then when i went to merg on the freeway, i pulled a drift and didn't get tracrtion till i hit third gear.the tires where spinning till i hit third gear. i was curious if the mazdas have a foctory posi or what do they have???
kaoss's avatar
kaoss
Post a pic of your tires.
scotto79
They have nothing fancy in them.  You probably just gave it too much gas on old tires.
1987bseiresman
oh!!! it seemed like it had a factory posi or lsd.my toyota has never done that. i 1 have a 1993 toyota 2wd pickup.it's lowered with a downey air-intake and flowmaster 40 series exhaust. i have tried to get the truck to do the same thing. i think it's weird asspecally because the toyota's 22re put's more power to the ground too!!!!
kaoss's avatar
kaoss
Not unless someone got in there and welded it up.
1987bseiresman
i didn't know that!!! thanks man!!!!
low intentionz's avatar
low intentionz
or iti could of been a 1rst gen rx7. those have a posi rear end although idont know what one person could benefit  from such a swap unless you likr to lite the tires.
1987bseiresman
it felt like a posi rear end.i didn't think a stock b2200 could put the power to the ground so quickly but it did.i looked mazda b2200 specs and theres a site that says they have a dana sytle rear end. i strted the topic because i wasn't sure what kind of rear end they have from the factory.if it took me to get into third gear to get traction.it must be a posi or lsd rear end!!!
