Parker Triple-Lok 2 fittngs
audio_sports@sbcglobal.net's avatar
k24 rd6's avatar
k24 rd6
Has anyone used the triple-lok 2 fittings with the o-ring on the flare? I Kind of like the idea of extra insurance in case the flare is a bit off but will they actually work better than a normal fitting without the o-ring?
Sal's avatar
Sal
As long as you don't over tighten the fittings, the flares should remain close to spec. The key is not mixing AN and JIC fittings. They are both 37° flare fittings but the sealing surfaces and thread thickness are in separate classes with material strengths. There are also 45° SAE fittings and these should NOT be thrown into the mix.. either make all of your fittings 45° SAE's or don't use them at all as to not have a chance to mix them up. Generally speaking, go with 37° JIC fittings as a standard as that is what is commonly available. Steel fittings are are a standard with oil based hydraulic setups seeing as it's very high strength and there is no worry of it rusting like with pneumatic setups. Just my $.02 I could see an o-ring boss on the flare helping to seal but not if that fitting were to be commonly cracked (or completely) open(ed). The more wear that o-ring were to see, the more likely it will be to fail. If this is a fitting you may rarely loosen up, I could see them holding up over time. Keep in mind, the more things there are to go wrong, the more things there are to fix when the shit goes down. I haven't looked into them much, any links for info on them?
