Toyota Trucks \  lowered motor on tacoma?
Toyota Trucks Make Specific
views 317
replies 7
following 6
ohioratrodder   +1y
I lowered the motor in my 1998 Tacoma and now my oil pan sits on the crossmember. Will i have to modify anything like the sump or pickup tube if i section the oil pan 1/2 inch.?
Full Blown   +1y
Lay a flat edge across your mounting flange of oilpan measure the depth then measure your pickup tube.
jtbeasleystc   +1y
Would it be easier to notch the crossmember and plate it back?? Thats how i plan to do mine anyway.
ohioratrodder   +1y
---------------------------------------------Originally posted by TBeasleySTCWould it be easier to notch the crossmember and plate it back?? Thats how i plan to do mine anyway.--------------------------------------------- i have to section my oil pan because it hits the ground and crossmember. Does anyone have pictures of sectioned oil pans?
rolnlowdotcom   +1y
here is a mazda not sure if its at all the same
ohioratrodder   +1y
are those oil pans from tacoms? if so what year
gdubsmsp   +1y
i lowered my motor 1" (because i raised my crossmember 1/2") and all i did was "straighten" the back of the pan where it hits the crossmember.  I cut it out and replaced it with a piece of sheet metal that is straight up and down instead of angled like the stock pan is.
