Air Ride Suspensions \  QUESTION ABOUT AVS DIGITAL GAUGES
Air Ride Suspensions Q & A
views 742
replies 6
following 7
DropEmWear   +1y
Edited: 5/6/2010 9:29:43 AM by DropEmWear
Anyone use them ? I have owned the dakota digital ones before and never had an issue with them. I like the whole plug and play idea with the AVS set. It seems like a good kit but just want to see if anyone had any issues with them. The only thing I am not fond of is the colored face and black numbers. I liked the dakota digital black face with colored numbers. It seems to show up better. let me know guys.
metal worx inc   +1y
we have used them here at the shop on customers rides no problems that i have heard about
foxkid   +1y
I have them now. Only problem i had was that one of the sending units went out. I sent it back, and they bench tested it, found out it was bad and sent me a new one. I love the set up.
jeebus @ mmw   +1y
Ive had mine for 3 years now, they have all but stop working completely.... Says i have 290psi in my tank, when my pressure switch is 175, all 4 corners of my truck will fluctuate from my ride height of 50psi, to awnyware from 8psi to 200psi, only for short intervals, if i hit a switch to adjust, it goes back to normal, but will act goofy again 2 minuets down the road.  all 4 of my sending units have gone out on me... I was told it was from moisture in my air system, but i have a line dryer installed after the tank and before the valves... i like them alot when they were working, but lately i dont even look at them.  Taylor
Marcos_65   +1y
They changed the senders recently to make them moisture proof
bodydroppedon20   +1y
i dont know how similar they are but i have the 200psi ones from f.b.i. for around 2 years now, i like them i had one sending unit bleeding out but they replaced it, but while the compressors are filling the tank it reads about 20psi more than whats in the tank until the compressors are off then it reads correctly ( just on the tank sender)
jumbo   +1y
i have some but they're not installed yet.  Gavin still has to get the floor welded in and the interior put back together before we can get anything like that wired up, but i'll let you know when they're running.  I liked the layout (4 corners and tank psi in the middle) better than the dakota digital layout (tank psi on left then 4 corners).
