Removing E brake system
bbluvn@yahoo.com's avatar
nc dragger's avatar
nc dragger
hey guys with a 84-88 toyota truck . what is involed in removing the e brake system all together from the hubs to the front.  thanks for any info.
cajuntaco's avatar
cajuntaco
Just disconnect the cables inside the drums, 2- 10mm bolts hold cables to backing plates and pull it out.  Remove hangers, and cables to the lever thing.  The lever thing (on trans x-member) has a pin with a cotter pin that holds it on, remove it.  The unbolt the e-brake handle inside the truck it has 2or 3 bolts and pull the cable up through the floor.  Put a grommet back in hole.  Done.
nc dragger's avatar
nc dragger
---------------------------------------------Originally posted by BagD72ChevyJust disconnect the cables inside the drums, 2- 10mm bolts hold cables to backing plates and pull it out.  Remove hangers, and cables to the lever thing.  The lever thing (on trans x-member) has a pin with a cotter pin that holds it on, remove it.  The unbolt the e-brake handle inside the truck it has 2or 3 bolts and pull the cable up through the floor.  Put a grommet back in hole.  Done.---------------------------------------------so does the lever that is hooked to the brake shoe come off after unhooking the cable ? or does it stay free floating ?
cajuntaco's avatar
cajuntaco
I would just leave it in there.
