Air Ride Suspensions \  WOW! I think I need to replace/rebuild my tired Viair 450's....
Air Ride Suspensions Q & A
views 965
replies 9
following 9
FADE2BLK94   +1y
I just ran both trucks, the 92 with one viair 380(3yrs old) and one 5 gallon tank from 0-145psi, and the 94 with two viair 450's(7yrs old) and two 5 gallon tanks from 0-175psi both trucks with the engine not running hooked to a battery charger maintaining between 11.8 and 12.5 volts. The 92 took 10 minutes to fill and the 94 took 34 minutes to fill!! I think I need to replace those 450's with the new 444's!
menace   +1y
i have dual 480s that are a year old, on 6 gallons of air, and it takes 3min to recover from 165 to 200psi, its supposed to take 1min 19sec, im not impressed with my compressors... when i had them on 5 gallons they werent that bad, i never calculated the time though
layed521   +1y
Jeremy, what size wire are you running? My 444s fill my 3 gallon tank 0-145 psi in just about 1 minute, maybe a few seconds over. Andrew, get with Ray @ Universal Air Suspension! http://www.myspace.com/universalairsuspension  Hes a good guy to deal with, fast shipping & the lowest pricing on a set I believe!
YUH8IN96   +1y
dam i got 1 480 on two three gallons an from 160-200  at the most it might take 3 mins an thats wit my sistem bangin an everything, somethin aint right wit urs jeremy. i heard those 444 are pretty bad ass ill stick wit my 480 for now tho
drpitlo   +1y
Not to undercut anybody but I can do the duall 444s for 300.00 shipped as long as your not way out west.
idrgbdy   +1y
wish i could fit an engine driven in mine. i'm almost ready to put my air ride back on. got (2) 480s that are about 3 years old. hope they still work. lol
Layumon22s   +1y
i think a lot of your problems are coming from your voltage. from my experience there is a huge difference between running mine at 11.8 volts and say 13 volts, almost like adding another compressor difference. also don't forget that the 450s aren't rated for more than 150 psi so pushing them to 175 isn't helping any. also viair probably rates their fill times at a very unrealistic 14+ volts that most people don't see with a truck idling with a constant 40 amp draw on top of everything else running.  the 380s are clocked at 7 min 20 sec for 0-145 on a 5 gallon tank. so considering your lower voltage 10 minutes isn't too far off.
FADE2BLK94   +1y
---------------------------------------------Originally posted by Layumon22si think a lot of your problems are coming from your voltage. from my experience there is a huge difference between running mine at 11.8 volts and say 13 volts, almost like adding another compressor difference. also don't forget that the 450s aren't rated for more than 150 psi so pushing them to 175 isn't helping any. also viair probably rates their fill times at a very unrealistic 14+ volts that most people don't see with a truck idling with a constant 40 amp draw on top of everything else running.  the 380s are clocked at 7 min 20 sec for 0-145 on a 5 gallon tank. so considering your lower voltage 10 minutes isn't too far off. ---------------------------------------------Yeah the 380 doesn't do bad imo. But those 450's are toast! I know that they are only rated at 150psi but I have been running them to 175psi for 7 years now, so yeah they are pretty much done for! lol. They still work but I've just noticed that they have started to take a lot longer to fill than they used too, even with the truck running.
menace   +1y
I use a stiger type relay, and i have 4 gauge wire running to that for my main power, and then i have the compressors wired directly to the relay, no undersized wire at all... plus im running a group 31 battery, and i have a 140 amp alternator, i havent checked to see what my actual voltage is at the compressors though, ill have to look into that
sleepyspeed   +1y
---------------------------------------------Originally posted by FADE2BLK94I just ran both trucks, the 92 with one viair 380(3yrs old) and one 5 gallon tank from 0-145psi, and the 94 with two viair 450's(7yrs old) and two 5 gallon tanks from 0-175psi both trucks with the engine not running hooked to a battery charger maintaining between 11.8 and 12.5 volts. The 92 took 10 minutes to fill and the 94 took 34 minutes to fill!! I think I need to replace those 450's with the new 444's!--------------------------------------------- if you go 444's you wont be disapointed, there fast and quiet.  I have a single 4gal tank and it takes about 2 min. to fill 0-145 and 30-40 sec. to go 110 to 145.  Engine idling and yota factory volt gauge reading about 13.5v.
