Mazda Trucks \  having clutch problem
Mazda Trucks Make Specific
views 326
replies 6
following 5
suicidemazda   +1y
i just replaced my clutch and slave cyl. about a month ago and i have only driven it about 2 miles and now every time i press in the clutch it makes a grinding noise. and it just started doing it today when i moved it outta the garage. has anyone ever ran into this problem or know how i could resolve this issue?
thanks
drpitlo   +1y
What year mazda and did you bleed the slave cylinder to get the full compression of the clutch?
suicidemazda   +1y
its a 88 b2200  and yes i did bleed it
mjavy7   +1y
Did you replace the thow out bearing while you were there? Those ofte sone like a grinding noice when they are going out.
slmmdd97   +1y
you may want to check the direction of the clutch disk plate to see if you accidently flipped it around the wrong way.  I know there are some apps you can run the plate both ways and some tat you can.  hope this helps
suicidemazda   +1y
throw out bearing was replace and ther is only one way u can put it all together or the tranny wouldnt bolt back up
AndrewB22   +1y
how about the pilot bearing?
