air brake tanks
air brake tanks
slow50
whats the max psi on an air tank made for air brakes? its old and its steel.
nissandoordragger's avatar
nissandoordragger
im 90% sure its 150 psi but the burst is like 3-400 psi i had one on my nissan for 3 years and had the psi up to 300 a few times when i forgot to turn off my edc so you can run 200 and be golden
hang time mazda's avatar
hang time mazda
120-150 is max that trucks use. on my Peterbilt, the air dryer bleeds off around 125 psi. I have seen some go 140-150 but not too many.
slammedxonair's avatar
slammedxonair
It should have a 150psi recommended pressure if it is DOT approved and a bust pressure of at least 500 psi if not 600 or more. But be sure to do your homework before hooking it up.
slow50
how do i do my homework on it? the guy that gave it to me said its military. and its never been used. its got the flat green paint on it.
THE LOW RANGER's avatar
THE LOW RANGER
i work for a transit company they stop building psi @ 125 130 the most nut they will hold 150 psi    just my 2 cents
slow50
well arent regular tanks rated at 150 psi too? has anyone ran one besides nissandoordrager?
9
90slammedmitsu
im running one ...i had one on my old truck as well and it ran to 175psi daily with no problems
slow50
ya i think im gona run it. thanks for the help.
s10
last post by baha +1y
