Ford Trucks \  a couple wiring questions...1999 Ranger 3.0
Ford Trucks Make Specific
views 253
replies 6
bigdaddypaco   +1y
I have a green wire with red stripe under the dash that clips somewhere, but cant remember and i missed marking it...also my theft system is activated and I dont know how to reset that...and the last thing is when i turn the left turn signal on, the flasher box starts to buzz...doesnt do it on the right signal...really hoping one of you can help me out with this...
low99maz   +1y
Edited: 5/28/2010 10:10:51 PM by low99maz
if you swapped dashes out of another truck than you need to change the lil black box above the air bag that is for the anti-theft system............the blinker might be a bad bulb or a crossed connection,or a shorted out blinker relay. What dose the connector for the green wire look like?
bigdaddypaco   +1y
Thanks...I think you are right on the crossed wire for the blinker, will check that tomorrow... the connectoron the green wire  is a little black box looking clip...probably no more than 3/8 of an inch... I still have the stock dash, but removed the airbags and put in a aftermarket steering wheel...I will look where the airbag was and see if that box is connected, I may have disconnected it...
low99maz   +1y
the little clip you speak of is for the e-brake or the horn i think....mine is dissconnected also so you shouldnt have a problem with that.......i put a dash out of a different truk in mine years ago and had to put my anti-theft box in the new dash so it would recognize my key!
bigdaddypaco   +1y
cool , thanks a lot bro!
bigdaddypaco   +1y
If I take out the airbags would that cause the theft system to trip
bigdaddypaco   +1y
never mind figured it out, had a couple grounds off...now to fix the turn signal wires and I am golden
