Ford Trucks \  need help with those damn ford clutch plastic lines
Ford Trucks Make Specific
views 609
replies 6
cookiemonster13   +1y
Edited: 6/6/2010 1:40:13 PM by cookiemonster13
hey guys, i am installing a 1986 ford truck transmission in a 1964 ford truck. so the factory lines will not work. i need to make some lines but as you know it is these roll pin connections not threaded. James thought summit sold an adapter to AN but i cannot seem to find them. PLEASE GUYS I NEED HELP!
gimp5561   +1y
can you not adp. to a cable  ???
cookiemonster13   +1y
not i can tell, sadly... i thought this tranny would be cable since the mustangs of the 80s were... no such luck.... it is one of those on the shaft slave cylinders also in the bell housing. i already hate this transmission and it is still in the bed of the truck....
bodydropped85   +1y
yes thats what i was talikin about.
instinct   +1y
depending on where you are in the country. a place called pirtek out of minnesota (where iam) specializes in things like that. they made my plastic clutch line for my ranger out of stainless braided line from the master down to the pedal and then to the slave.
cookiemonster13   +1y
thanks for the info. i ended up using the stock one. luckily it was flexible. that fitting i found at jegs is right for the master but the slave side is like 1/2" quick disconnect
