Isuzu \  Rodeo mirrors on Pick-up doors....it can be done!
Isuzu Make Specific
views 472
replies 1
following 2
VC REEVES   +1y
After going round and round on the net, I finally went to my local salvage yard. To do this, all you need is a 10mm socket, Phillips head, and a 5/16 Drill bit.
This is the before....you have to remove the track and molding, so get all that from your doaner.
Next you will have to drill two holes. The upper part of the mirror bracket will only get one screw, but with the window track and every thing tight, don't worry about it.
The window track will bolt into the mirror bracket, and there is a hole at the bottom. You will need to drill out for the upper mount on the window track.
Here is how she will look once the  mirror is bolted in. Trow the new moldings in, and rock it out....
*********oh be sure to get the window too..... They are different.
Only takes a lil' time to do, and looks much better.
tacokane   +1y
Just another tip for all you isuzu freaks. The bigger glass and crank assembly also requires three holes to be drilled in the middle of the door to mount the second part of the crank assembly, just make sure to note those spots on the donor and its easy to match to your door. The manufacturer has already flattened those spots they just didn't drill them out so its really simple and cranks much eaiser. And if you decide to switch to power then the motor uses the same three holes.
