Mazda Trucks \  separating hub fror the rotor on a 88 b2200
Mazda Trucks Make Specific
views 351
replies 3
suicidemazda   +1y
hi i need to change some wheel studs and on the front i can not figure out how to separate the rotor from the hub, i think thats what its called. i took out all the necessary bolts and tryed banging it off with a hammer and still nothing.  i will post pics tmorrow.  thanks in advance
brennan
kaoss   +1y
So you removed the entire assembly as a unit off of the spindle, them removed the bolts on the back side that hold the rotor to the hub? My bolts were a bitch to get off. I put the socket and ratchet on the bolt, then held the rotor in my hands and slammed the ratchet handle into the floor until they came loose.
suicidemazda   +1y
yup its all off the spindle. and i just used an impact to get them off
warpedrenderings   +1y
Edited: 6/17/2010 12:22:49 PM by bamfben
hit it harder, if your not reusing the rotor try smacking it. if you are get a small peice of 2x4 and put it against it and hit it.  or put a good shop rag on the rotor clamp it in a vise and hit the hub.
