Chevy/GMC Trucks \  1995 s10 blazer 4x4 help
views 399
replies 0
following 1
wirenut   +1y
Edited: 6/22/2010 3:48:10 PM by ZROGRDCRLANTS
hey sorry this may be long but i really need help. i bought a 1995 s10 blazer it had a rough idle and was throwing a tps code. so i changed it. the idle got alittle better. then it started throwing a p1345 camshaft to crankshaft position correlation fault . so i changed the camshaft sensor, also changed out the distubtor with the crankshaft sensor,the ear on the dist. was broke off as well . afterchangin the dist it ran alot better. then a random misfire code came up. so i started doing everything cap ,rotor, plugs,wires . nothing is clearing the code. so i pulled the plentum off to check the injector hoses and injector.does not seem to be any cracked hoses.question , is there a way to check the injectoror? or clean the injector and hoses?also is there anything else anybody can think of that i may have missed and may try?.
