Compressor issues help please
nyterydrtuckn26s@aol.com's avatar
Nyterydrtuckn26s's avatar
Nyterydrtuckn26s
Today i turned on compressors to fill tanks and raise the  truck up out of all 6 viair 480s there seems to be only three  working which really sucks. so should i just  replace the non working 480's or buy  air zenith compressors  or find someone that can put an engine driven on my truck  which is  a 2003 ford f-150 with  5.4 liter engine.  all ideas or suggestions  please  help
msturg's avatar
msturg
if 3 of them quit working at the exact same time, I'd suggest double checking that it isn't simply a wiring issue and that the compressors are completely fine.  Don't know what would cause 3 seperate compressors to fail simultaneously
low99maz's avatar
low99maz
What type and how many relays r u using
Nyterydrtuckn26s
each compressor is on its own relay . same relays that come with compressors
msturg's avatar
msturg
have you done any electrical inspection yet?  Made sure the relays are clicking over?  Made sure that all compressors are receiving power?  I would also suggest all fuses, make sure that they haven't simply blown in a manner which still allows a small amount of voltage to cross which can sometimes trick a meter.
low99maz's avatar
low99maz
I would switch to the 80 amp relays that Suicidedoors sells, run 1 relay for 2 compressors use 4 g wire
s10
last post by baha +1y
