Toyota Trucks \  Taco SFBD questions...
Toyota Trucks Make Specific
views 372
replies 6
Tacon19s   +1y
Edited: 8/16/2010 10:18:05 AM by Tacon19s
Gonna try this again. I just got a new cab for my taco that I plan to stock floor. Id like to know if using 2x3 to re-build the rails will give me enough room to lay pinch WITHOUT CUTTING THE FLOOR. I refuse to cut the floor at this point with the exception of the tranny/driveline tunnel. I will use dual 2x2 rails per side if I need more room but would rather not.
Somebody help me out here...
Tacon19s   +1y
Edited: 8/16/2010 10:18:41 AM by Tacon19s
 anybody?
Tacon19s   +1y
anyone?
tre5   +1y
YES. 2x3 will allow you to lay pinch without cutting the floor for the frame rails. The one I did had a IRS rear end, so I had to cut the floor for the driveshaft. If you have a carrier bearing in your driveshaft you will probably be fine without cutting for the driveshaft.
toywitu   +1y
i am stock floored on 19 layin rocker  and  my floor isnt cut at all really  and driveshaft tunnel works  only spot uct and modified was gas tank was raised in compartment behind back seats  so it could stay in stock location check out my frame pics
Tacon19s   +1y
Edited: 8/16/2010 12:14:55 PM by Tacon19s
Thanks very much guys. Its been killing me to know so I know whether to get 2x2 or 2x3 and I havent really gotten into it yet. Phil, are you saying you are to rocker (with 2x3) and didnt have to cut the floor at all...just the tranny/driveshaft tunnel?   I am just going to pinch myself....my current cab is a little past rocker and I hate looking at my rockers. After years of laying on them they tend to get wavy.
toywitu   +1y
Edited: 8/16/2010 2:20:13 PM by toying02
yea mine is to the rocker with 2x3  on 19s  and floor is stock
