Mazda Trucks \  pulling cab off frame ?????
Mazda Trucks Make Specific
views 459
replies 5
following 6
gimp5561   +1y
ojk we are going to pull the cab off my b2200 sat..  what are the little hidden things too look out for while unbolting the cab
also taking out the dash so where are the hidden bolts at in it
the truck is an 88 extra cab
ALSO LOOKIN FOR A SHELL FOR A EXTRA CAB B2200
h2omelon(nick)   +1y
It's pretty straight forward Me and Wes did it in the junk yard with simple hand tools in about 45 minutes. Just the brake lines on the firewall and the steering basicly.
nc4life   +1y
Edited: 7/22/2010 2:56:39 PM by crewcab
Not to bad.  You have the steering column, brake lines, there are 2 nuts on each body bolt, the harness that comes out of the rear wall has a plug just inside the cab, you also have one brake line attached to the underside of the extra cab section, a/c lines if you have a/c, coolant lines for the heater core and I'm sure there might be a few things I forgot but I'm sure you guys can handle it. Speedo cable also.
Rob Clayhill   +1y
There is probably a drive shaft hoop, few random ground wires underneith. Pulled an entire cab in 45 minutes?? was it pretty stripped to begin with?
h2omelon(nick)   +1y
The engine bay was already stripped. There is not a drive shaft hoop.
kaoss   +1y
Edited: 7/22/2010 8:20:40 AM by KAOSS
Throttle cable and parking brake!
