4WD hub assembly questions WHAT YOU USE?
1 following
coolcarguy89@aol.com's avatar
pimptruckman92's avatar
pimptruckman92
Edited: 7/27/2010 9:44:05 PM by truckman92
I've been watchin a few of the builds with all new suspension components such as just_robert's s10 pickup build and my question is:
what kind of hub assembly would be the best option, W/ Pulse vacuume? ABS?
by that I mean there are several styles available for the 4WD ranger hubs I want to buy.
http://www.partsgeek.com/mmparts/wheel_hub/ford/ranger.html
oreilly also has these parts but different brand and none show pulse vacuume online... but do show ABS
my truck from factory is not a ford and only has front ABS to my knowledge, and I'm sure it wont be a plug and go type thing but should I just get the cheapest one with ABS to work?
WHAT DO YOU USE and if not using the ABS Cable do you remove it and cap the hole?
