asco valve sticking...
1 following
draggin95niss@live.com's avatar
draggin95niss's avatar
draggin95niss
i have a 1/2" asco brass valve that keeps cutting out, its the dump on the front left, when i hit the switch it does nuthin, but if i get out and twist the coil back an forth it will work for one pull, now if i pull the coil and put it back on it will work for w few pulls but then goes right back to the way it was...there is a replacement coil availible, but my question is should i replace the whole valve or does it sound like an issue with the coil?
btw:
the wires are soldered so the connection isnt loose....
