Air Ride Suspensions \  info plz
info plz
Air Ride Suspensions Q & A
views 272
replies 2
following 2
heavyblackchevy   +1y
wats up,my name is Eric and im from Arkansas.Ive been reading alot on here but i have some questions about bagging and i now nothing.My truck is a 08 4dr silverado on 22 inch Zons .I have it lowerd 2/4 now and i raised it from 4/6 b/c of frame /axle hitting ,tire rube in finder and tire on fender lip.I want to bagg it but i now nothing about quality parts to buy and wear from.i now wat all has to be done to bed and frame but im wondering about front on this truck.to lay frame will i have to cut firewall on 22 or 24,s and i see some set ups are air struts and outhers want you to cut mount off and weld in a relocate plate ,like trhe front end kit from exstensive meatal works who makes the right stuff or should i say the best kit?.I need this to be built for day to day driving and to pull small trailer , ride qoulity is a big deal my lowering kit rides horriable .how do baggs ride i now no one that has a bagged ride.So just wanting to know alot of info on doing this thanks,er
lowkid37   +1y
whats up man i have an 08 myself, it is bagged. i used the extensive front and rear kits on my truck and both are highly recomended. the ride quality is amazing, almost like stock if not better. the only thing i dont like about the front kit is the shocks hit my stock 20 wich cuts my turning radius way down but you probly wouldnt have that problem with bigger wheels. it wasnt to bad to install, i like doing stuff like that so it was fun for me. i would recomend either the exstensive kit or if money is not a issue the choppin block kit. also check out gmfullsize.com for a ton of info on these trucks and anything i can do to help just ask man.
heavyblackchevy   +1y
cool man thanks for repling. wat type of air setupe did u get .i no nothing about this or wat i need .like compressor size tanks all that stuff i have no clue.if you have some more pics i would like to see them to like yor front tubs setupe thanks eric
