Full Size Truckin General \  hydroboost?
hydroboost?
views 254
replies 4
mazberrydelight   +1y
does anyone have pictures/ directions on where to run the lines on a hydroboost system/ powersteerring. ive started reassembling my 98 dually and have no idea how to hook it all up , itwas all torn apart when i bought it . thanks
project94   +1y
The factory lines?  One line goes from hydroboost to the ps gear, the other line goes from hydroboost to the steering pump, then run a T fitting on the back of the pump and hook up the return line from the steering gear and the hydroboost to these
mazberrydelight   +1y
thanks , any idea what line coming out of the ps pump is the high preasure . your explanation is perfect , im just not sure where to hook the lines up to on the ps gear and the hydroboost.
project94   +1y
There's two lines on the hydroboost, the stock lines will only fit on one way due to the angles the lines are bent at, the longer line goes to the steering gear, the shorter one goes to the pump
mazberrydelight   +1y
thers 3 lines on my hydroboost, i went toa junk yard and took a look and have it all figured out now , thanks for the help
