i wanna clean up the windows on my luv and was wondering if light scratches can be removed or hidden. if so what should i use?
nopinch
Yeah they can be sanded out. I do it at work all the time, we have a kit that is just an angle grinder with a sanding pad attatchment. You pretty much just wet sand it and then buff it out, the trick is to not get it too hot and keep lots of water on it.
marcus45
summit racing sells a kit with a powder called cerium oxide. comes with a drillpad attachment for around 35 bucks. just follow the directions for use.
waynehammer
Awesome. Thanks guys
low99maz
Check out c.r. Lawrence also....they sell glazing supplies. The brown oxide and white felt pad work awesome as stated above.....jus keep it sloppy wet
dbldub01
---------------------------------------------Originally posted by low99mazjus keep it sloppy wet ---------------------------------------------
