Toyota Trucks \  OBD CODE 41
OBD CODE 41
Toyota Trucks Make Specific
views 757
replies 3
framescr8pintoy   +1y
has anyone ever had an error 41 code? tps sensor, tps signal, tps circuit, ecu.     ive already tried another ecu, and tried another tps sensor awhile back and had same results. so im thinking possibly wiring somewhere. any ideas that maybe someone else has come across?     '91 22RE 5SPD.
bman619   +1y
Edited: 8/30/2010 4:11:08 PM by bman619
I have the same code, my wire harness that connects to the TPS (4 wire connector i believe)  is loose and wornout so the computer does not get the proper signal back everytime.  sometimes i can move it around or zip tie some tension on it and the check engine light goes away for awhile but it always seems to come back. new connector would probably fix it but the junk yards around here are usually picked over.
bman619   +1y
Edited: 8/30/2010 4:11:35 PM by bman619
framescr8pintoy   +1y
had a bad tps sensor and bad o2 sensor.
