84 Toyota SR5 22RE...Need an electrical GURU PLEASE!!!
POSJustin@gmail.com's avatar
POSJustin's avatar
POSJustin
Sooooooo....
My boy has a 84 Yota SR5 22RE Fuel Injected...hes had a ton of problems suddenly pop up. he was cruisin home one night (said he wasnt draggin') and all of a sudden!!!
-no tail lights-no blinkers-no running lights-no altenator power-no gauge lights-key wont turn the vehicle over/gotta hot wire it-no power at all to some fuses/in or out
just replaced the altenator today, it was bad, new ingnition installed, i found a bunch of wires drug through, replaced them. still nothing...
any takers???
thanks for the help fellas...
NC rdgr8r's avatar
NC rdgr8r
Check all the big fuses in the Fuse box under the hood their should be one for Ignition or Starter my 94 did that once and thats what it was Check it out Good Luck....
2lowtoy
^^^^^^^Yep there is a couple main power fuses in the under hood block. Thats what its sounds like to me too.
obey's avatar
obey
You might want to try to replace the tail light control relay. this blew in my truck and knocked out the rear tails, the gauge lights and basically just messed everything up.
9
92LOWYOTA
If everything listed by everyone else is good try all the grounds. Bad grounds can cause some crazy shit to happen.
rolnlowdotcom
There is a fuse link on the white wire coming off the battery some times they are under wire loom that is the main feed wire
Is any thing at all working or is every thing dead??
POSJustin's avatar
POSJustin
cool, ill start with these ideas. rolnlowdotcom, i believe the headlights and markers work. i was only able to see the truck run for like 2-3 minutes before the battery died. i truely appreciate everyones time and help!!!
framescr8pintoy's avatar
framescr8pintoy
if he wasnt draggin then how did the wires get drug through, assuming you got the wiring reconnected to the correct wires then yeah check those fuses, and make sure the ground wires are good and tight. im going through wiring issues with mine and it sucks but you learn alot tracing wires down and how much unneccessary wiring is in there.
