Chevy/GMC Trucks \  98 s10 ignition diagram
views 5171
replies 3
HollywoodFMX   +1y
im having wiring issues with my 98 s10 ss and im alomost certain its a short in the system... only problem is, i cant find a wire diagram anywhere! where can i find one other than a repair manual like haynes and chiltons... let me know if you know of a web site!!!
Slappy Mc Nasty   +1y
i found this so far, will keep looking for ya
98 + S-10 or blazer
12volts red + ignition harness
Starter yellow + ignition harness
Ignition pink + ignition harness
Second Ignition white + ignition harness
Accessory orange + ignition harness
Power Lock lt. blue + brown plug at BCM
Power Unlock white + brown plug at BCM
Lock Motor gray 5wi driver kick panel
Unlock Motor tan 5wi driver kick panel
Parking Lights+ brown + lt. blue plug at BCM
Parking Lights- white - lt. blue plug at BCM
Door Trigger - BCM
Dome Supervision use door trigger
Trunk/Hatch Pin pink/black - lt. blue plug at BCM
Trunk/Hatch Release black - purple plug at BCM
Tachometer white ac PCM
Brake Wire white + steering column
Parking Brake black - at the pedal
Horn Trigger black - steering column
AVTekk   +1y
There are no diagrams online because theyre copyrighted. Id pick up a Chiltons because you'll use it pretty often if you do your own work. Stay away from Haynes, its complete garbage.
HollywoodFMX   +1y
sweet sweet, yea i know haynes are shit cuz i sell them at my work lol
