Air Ride Suspensions \  First timer in need of some Knowledgable help!?
Air Ride Suspensions Q & A
views 527
replies 4
NoVaLongbed   +1y
So I plan on bagging my 93 Ranger & of course its my first time bagging a vehicle. Here is what I have in the parts closet already... 2-Viair 450C, 2- ContiTech 2500 SV, 4-SMC 1/2" Electric valves, 1-kp Single & 2-kp double needle gauges, 1-"Adjustable" square D pressure switch. I know I need more Air System wise but, Here are my questions. Will 2500 bags be enough for the front? Here is my cart on Suicidedoors. With everything in the cart, What more will I need suspension wise to be able to get to work? I know another bar in the rear for the bridge...correct? Also it is already on round DJM dream beams & will not be Yota clipped! In the front other then notching the frame for the tie rod ends, Will I need anything else to do the front? other then bags & air system of course. Here is my cart,http://www.suicidedoors.com/cart Thanks for the help, tips & any advice in advance!! Sooner I get my licenses back & This thing bagged the sooner I can move to FL WWWOOOHHOOO
phat phabrikationz   +1y
Umm yeah, your cart link is just to an empty cart!
NoVaLongbed   +1y
Sorry! Here is the links to the 2 things in my cart...http://www.suicidedoors.com/bag-brackets/bracket-kits/pre-1997-ford-ranger-bag-bracket-kit
http://www.suicidedoors.com/4-link-kits/thorbecke-brothers/super-llift-wishbone-kit
drpitlo   +1y
What size wheels are you going to run? Is a body drop in the future? I would suggest getting more valves at least 2 more for the front, being if you run both fronts just off of a fill and dump valve you will get alot of body roll so you want enough valves for each corner. 2500# bags will lift the front, on your superlift wishbone setup are you planning on running a fuel cell? If not you can not use that kit the upper bar will not clear the gas tank. As long as you have the dream beams and notch the rails for the tie rods you should be fine.
If you have any questions or need any help getting parts let me know.
drpitlo   +1y
Also you dont need both of those kits from suicide doors because the kits both have rear bag mounts
