Ask A Pro \  Frame Table
Frame Table
Ask A Pro Q & A
views 512
replies 1
following 2
obey   +1y
Just wondering what type of casters you would use for a frame table. I will be putting a standard cab 93 yota frame on it. I would like the tops to be threaded for adjustability also. How thick would i need the top plate to be and any misc pointers would be great. Thanks a lot!
TacoFel   +1y
The best bet is to use a caster with all steel construction or with a cast Iron wheel. Use the caster for the mobility of the table, not the leveling of the table. On mine I have 360deg swivel casters on all four corners and then levelig pads adjacent to the casters that have enough adjustment to pick the caster off the ground and level the table. This way the table is firmly in place and level. I have cad and pdf files of mine if youd like to see, drop me a PM.
