Mini Truckin General \  mighty max
mighty max
views 278
replies 3
96lincoln   +1y
i have a questin a guy wants to sell me a 1986 mitsubishi mighty max. but the only catch is that its a 4x4. i dont no if this will work but my thought was to use a drop spindle, toyota hub swap to make it 5 lug but i dont no if it would work. i realy hope someone can help me out couse id like to get the ball rolling on this project thanks for the help
tre5   +1y
different frame than the 2wd. If you want it to lay you are going to have to strip the entire front suspension off and build new or clip it with a 2wd frame.
ahab   +1y
And chances are the tranny hangs way down since its a 4x4. So now your talkin new front clip and new tranny. These trucks arent that expensive. I would try to find a 2wd.
96lincoln   +1y
well i got a diffent motor and all for the truck. and i now a 2 wheeldrive is easier but i got the truck for 50 bucks so i was trying to make due and remove the 4x4 stuff and use the arms that are there and adapt the cups and drop spindle off a 2wheel drive. and toyota 5 lug swap supose to get it tomorow guess i could thro up some pics and look real gud at it and see. thanks for the comments
:DRAG:
