wiring up turn signals
ssm@bigjohnsondesigns.com's avatar
idrgbdy's avatar
idrgbdy
so i have headlights/tail lights/license plate light hooked up to a toggle switch. and i have the brake lights hooked up to a brake light switch. everything is all custom wired and works just fine.
i do not have turn signals, but i'd like to for when i drive at night to be more legal since no one would see my badass hand signals. i have no stock fuse box, flashers, or anything else stock. what do i need to get them to work? i have the custom classic LED's hooked up right now. i did find this on summit's site, but don't know if this is what i need or not...
http://www.summitracing.com/parts/PRF-30120/http://static.summitracing.com/global/i ... uction.pdf
that seems like a lot of money to spend on some wiring, relays, and flashers. i'm sure i could take their instructions and recreate a cheaper version. anyone have any thoughts?? it would be nice to be able to use my stock turn signal switch on the column ('96 gmc sonoma). thanks!
bodydropped85's avatar
bodydropped85
all you should need is a wiring diagram and a 2 dollar flasher from the parts store to hook up your signals. could prob hook up your factory hi beam switch while your at it lol.
Grant Kustoms's avatar
Grant Kustoms
if you are going to use a traditional American rear set up (brake and turn on the same bulb) you need a turn signal (the easier way) or two relays and a double poll double throw toggle switch (a total of 6 connections) in order to keep the brake light voltage from back feeding into all your signal lights.
let me know what way you are going to go and I can help you with the wiring
