Chevy/GMC Trucks \  Swing Bearing Problem
views 379
replies 1
following 2
JboyDrags   +1y
whats up fellas, i dont really post alot but i need some help. i got a 93 chevy extended cab silverado. its bagged using a tri. 4 link out back. the swing bearing keeps screwing up. i had some 1 locally bag my truck. i watched him set my pinion angle (i thought). what can b done 2 fix the problem. i believe i got 2 peice drive shaft also. do i need 2 get a 1 peice driveshaft made? fab up a new crossmember? n e help would b grteatly appreciated
Cyrus   +1y
I used to be the driveline manager for a company in Memphis, I'd probably do a one piece, back when I was doing it, about six years ago it would cost you about $120 to $160 to build one using parts off of your old shaft. Your shop will need measurements from center cap to center cap of u-joints with your truck in ride postion, just in case the distance from your diff to transmission may have changed a little after the new four link.
