Air Ride Suspensions \  need help valves sticking
Air Ride Suspensions Q & A
views 399
replies 2
following 2
shellhart   +1y
why is one of my valves sticking but only when the tank has a good amount of pressure in it... it is on my train horn and is really annoying.. only time i use the horn is when i need a horn because the truck doesnt have one but i dont want to drain half the damn pressure out of my tank when i use it.. what would cause a valve to stick and how to i fix it?
Marcos_65   +1y
What kind of valve and what kind of pressure are you running? I know sometimes my buddies 3/8" smcs stick when he forgets to turn his compressor off and it has over 250 psi, since there aren't rated that high.
shellhart   +1y
not sure what brand part number is SC666-15 if that helps it is rated it says 150-210 psi and my pressure switch cuts off at 200 but it doesnt have to be full to stick
