Air Ride Suspensions \  pinon angle & vibration problems
Air Ride Suspensions Q & A
views 952
replies 12
following 6
ohioratrodder   +1y
Does anyone know a good shop/or person in southwest Ohio who could help fix a vibration in my truck. Its a 1998 s10 std cab short bed 4cly auto, with air bags and suicide doors bolt on backhalf. I have adjusted the pinon and it did not help. Took my driveshaft and had it balanced and new u-joints put in, they told me it was not to long. If i lift the truck up to almost stock the vibration goes away. Only thing i think it maybe is the driveshaft is to short.
low00range   +1y
Are the SD kit link arms adjustable? sounds like it needs some tweaking. Check over all your hardware also.
unusualfabrication   +1y
Is the driveshaft one piece or two? When you adjusted your pinion angle did you go off anything or did you just guess and drive it?
low00range   +1y
standard cab shortbed should be one piece if im not mistaken.
Edited: 2/16/2011 11:14:34 AM by UnusualFabrication
LOL, I didn't even see that in his post! I like to set the truck at ride height and get a measurement off the tailshaft. If the tailshaft measurement is 3 degrees down then I make the rearend 3 degrees up (equal but opposite angles for one piece driveshafts). Depending on the suspension and what the vehicle is doing will change some things.
ohioratrodder   +1y
Yes it is a one piece drive-shaft. The tail-shaft is 5
If everything is mechanically sound in the driveline (u-joints, driveshaft, etc.). You could try and shim up the trans a bit.
TOYBOY89   +1y
Check your transmission and motor mounts, they could be worn out.
cookiemonster13   +1y
at ride height there should be 3-5 degrees of differnce between the two joints not 10.
AVTekk   +1y
You need to shim your tranny up about 1/2"-3/4" (any more and it will hit the floor), then set your pinion around 2-3
