Ranger fuel pump question...
bdpaco2003@yahoo.com's avatar
bigdaddypaco's avatar
bigdaddypaco
I have looked but dont see this anywhere, I have the E85 3.0 V6 and the fuel pump went out. From what I have found the fuel pump for the E85 is at least 2-3x the cost of a non E85 fuel pump for the same engine. Is there any reason why I cant use a non E85 fuel pump? or would I need to replace the fuel rail to a non E85 fuel rail as well?
j&jkustomz's avatar
j&jkustomz
What you would need to do is cross reference your injectors, Rail and find out the Pressure on the pump itself! If the all much up then you should have a problem! I don't see what the difference would be by putting the other pump in! I did a Racking Pinion swap and there was a big price difference in the single cab versus a extended cab and the rack was the same but they wanted almost $100 more! STRANGE
Dejavu's avatar
Dejavu
what year is the truck? i have a fuel pump out of a 2000 that id sell ya real cheap
