Hydraulic Suspensions \  can you use one pump?
Hydraulic Suspensions Q & A
views 947
replies 5
following 5
brooks0729   +1y
kinda of a dumb question but can you use one pump to run your hydro system? if so where can i find a wiring dir? i had one pump go out so just wanted to see if i could use one pump. thanks
n2bnlow   +1y
Yes, but you'll need a hydraulic manifold. Look it up.
:XL:
BK2LIFE   +1y
with the extra hassle of redoing your lines and wiring, itll be easier and cheaper to fix your pump
FXDGRND   +1y
You can run one pump. You can run either a manifold or multiple dumps. 1 pump 5 dump all the way up to 1/8. Any of the hydro gurus on here should be able to explain how to wire it up.
brooks0729   +1y
i think it might be cheapier to fix the pump. not sure how but i'll try. thanks guys.
2LOW4U   +1y
THESE ARE FROM HYDROHOLICS
Here is how to wire your switches for a 1-5
http://www.hydroholics.net/PDF/1-5diagram.pdf
You can do it with alot of fittings instead of a manifold seen here:
http://www.hydroholics.net/PDF/5-dump-plumbing-diagram.pdf
