Isuzu \  Gas tanks
Gas tanks
Isuzu Make Specific
views 581
replies 1
following 2
alter ego   +1y
Ahoy. I was wondering if the gas tanks are the same for the 90's pups and rodeos. I need to get a tank for my pup and need to know incase I cant find a pup in the junkyards.
sponge splawn   +1y
Edited: 3/31/2011 2:50:04 AM by isuzusponge
Hey Josh. Rodeo and pup tanks are not the same. Rodeo tanks sit behind the rear axle and are mounted side to side between the frame rails. Pup tanks are mounted front to back halfway under the cab and bed under the passenger side. Also note that the standard cab shortbox has a 12 gallon tank, while the Spacecab and the standard cab lokfngbox have a 20 gallon tank. If you were thinking of 4-linking your truck, the Rodeo tank could fit nicely in the back, but you would have to make your own mounts. I'm not sure if the sending unit will jive though. Good luck, Sponge. :SP:
